peter-vddriessche avatar image
peter-vddriessche asked
Trouble with Mode 2 connection to the "settings" service, cannot write to register 2700
I want to do time shifting using Mode 2.
But I'm having trouble connecting with Mode 2.
My Modbus TCP connection works. I can write for example register 22 which sits on the Unit-ID 246 (com.victronenergy.vebus). I an also read registers. So my modbus connection works .
But I cannot write register 2700 which sits on the Unit-ID 100 (com.victronenergy.settings).
When I look at my system on the VRM Portal, I see under Modbus TCP Services, the following list, where 'com.victronenergy.settings' is missing. Could this be the reason I cannot write 2700?
Any suggestions to solve this?
Best regards
Peter
com.victronenergy.system
com.victronenergy.battery
com.victronenergy.hub4
com.victronenergy.pvinverter
com.victronenergy.grid
ESSModbus TCP
peter-vddriessche answered ·
Problem solved. it was a program issue. Nothing to do with the Victron services.
Sorry.
Thanks for reporting back, I don't fully understand the issue or solution, but is there anything you could explain further if someone else comes across the same problem to help them?
peter-vddriessche avatar image peter-vddriessche Guy Stewart (Victron Community Manager) ♦♦ commented ·
Hello Guy,
I am programming a battery steering algorithm in VBA excel. I had followed a very interesting online course on Udemy for this
https://www.udemy.com/course/how-to-program-microsoft-excel-as-a-modbus-master-hmi/learn/lecture/21224098#overview
Reading several registers in one go (ie using one 'handle' for a series of addresses) worked fine. The error I made was that I tried to write also several registers in one go. That did not work. When I changed this and wrote one one register per handle, it worked.
Best regards
