mauronic avatar image
mauronic asked
What gauge wire should I use for KUS sensor + Cerbo?
I am installing this KUS sender (tested and works with the Cerbo GX on my bench) in a tank for my van. How do I spec the wire gauge for a 25' run?
The sender has 18 gauge leads but I am not sure how much of a factor wire resistance is for a resistive sensor.
tank monitor
Your link was nerfed.
KUS sensor.
ewalderasmus avatar image
ewalderasmus answered ·
I have used a similar sensor, with a 10m run, and I used 2.5mm^2 cable. I know it is overkill but had it lighting around. Because it's not a high current part you can probably get away with much thinner wire. But this you could test on your bench as well.
agroventuresperu avatar image agroventuresperu commented ·
off topic, but did you ever figure out a solution for your pylontechs?
Sarah avatar image
Sarah answered ·
18 gauge wire should be fine. You can manually calibrate the sensor to take into account any additional cable resistance.
