Javier Vegas avatar image
Javier Vegas asked
Example of active alarm in installations API call with extended=1
I am working in an web app that has to use the API to get the current alarms. I found that the installation calls provide the current alarms for each installation when called with extended=1:
"current_alarms": [],
"num_alarms": 0,
The issue I'm having is that I can not find a sample of the data returned when there is actually an active alarm, nor in the documentation nor in the systems I have to test. Can any of you provide an example of an api response with an active alarm, please?
Thanks!
alarmapi
