vectra avatar image
vectra asked
MultiPlus 12/1600/70 - MK3 USB - How to connect
I have one question. If I want to change or adjust the charging of the Multi with the MK3-USB interface, I always first disconnect the Cerbo GX from the Multi (pull out the network cable). Then I connect the PC with the MK3-USB interface. Can I keep the Cerbo GX connected (in parallel) when I connect the PC? Or is it better to only connect one device to the Multi at a time?
Greetings, Markus.
P.S.
Sorry for my bad English. My mother tongue is German.
MK3
klim8skeptic avatar image
klim8skeptic answered ·
It is ok to have the mk3 connected to your Multi 12-1600-70 at the same time as the Cerbo is connected.
The Multi will only communicate with 1 device at a time, ie a mk3, and block comms with the GX device.
I unplug my mk3 from the computers usb port when not in use.
vectra avatar image vectra commented ·
Hello and thank you for the answer.
Great, then I'll handle it a bit easier now, connect the MK3 in parallel if necessary and then remove it again.
