ketanshah avatar image
ketanshah asked
connecting two cerbo GX in same one bus
Can 2 Cerbo GX units be used on the same bus ?
how many MPPT, chargers and smart-shunt i can connect to 1 Cerbo GX ?
cerbo gx
wkirby avatar image
wkirby answered ·
You cannot combine two CerboGX in one system. Each CerboGX is for a separate system.
Natively, you can connect three VE.Direct devices (MPPT, SmartShunt) to the VE.Direct ports.
For more VE.Direct devices you can connect to the USB ports via VE.Direct-USB dongles, natively two USB host ports are available. For more USB devices, use a good USB hub to expand the number of USB ports for devices.
A maximum of 15 VE.Direct devices are allowed on a CerboGX.
Check the comparison table here:
https://www.victronenergy.com/live/venus-os:start#comparison_table
