jcarnouil avatar image
jcarnouil asked
Easysolar-II GX ESS Error in DDC Program
Hi there !
I just installed an Easysolar-II GX with 2 x Pylontech US2000 batteries and have "Error in DDC program" alarm.
I added the ESS Assistant with VE-Configure but it does not appears on the GX Remote Console.
Also, on the Easysolar LCD, HUB-1 is displayed.
So maybe there is a conflit between HUB-1 an ESS Assistant ? (But I do not have HUB-1 assistant setup in VE-Configure).
Any help is welcome
Thanks in advance
PS/ Public access to my installation : https://vrm.victronenergy.com/installation/181865/share/b5dfc2b8
Multiplus-IIESSEasySolar All-in-One
jcarnouil answered ·
I tried to "clean" the Assistants with VE-Configure and reinstall the ESS one, but the problem is the same.
I got "#6 DDC program error" alarm ..
I really don't know what can cause this error :-(
@Matthias Lange - DE or @Thierry Cortassa (Victron Energy Staff) , may be have you an idea to solve my problem ? Thanks in advance -Jean-Claude (Bergerac - France)
netrange avatar image
netrange answered ·
Are the Pylontech Batteries correctly connected to the GX Device and shown in the Remote Console ? Correct Communication Cable ... Type A or B ... used ?
jcarnouil avatar image jcarnouil commented ·
Yes, they are well connected and they are charged by the MPPT, which is stopped because they are full. It's the Multiplus II who is in a strange state alternating between "OFF" and "UNKNOW" state.
capture-decran-2022-06-05-a-081439.jpgcapture-decran-2022-06-05-a-081324.jpgcapture-decran-2022-06-05-a-081308.jpg
Never saw that error.
https://www.victronenergy.com/live/ve.bus:ve.bus_error_codes
All FW up to date?
What components do you have (list all)?
Check the data wiring. Do you use DIY cables?
4 comments
Yes, all firmware up to date.
- EasySolar II GX :
-> SmartSolar Charger MPPT 250/70 v1.59
-> MultiPlus-II 48/3000/35-32 (ACOut2 switchable) v497
-> Venus GX v2,87
- 2 x Pylontech US2000C :
- VE.Can to Bus-CAN Type A Cable (with dongle on 2nd RJ45 GX side)
- ET112 meter on grid side
- Only AC In used (for now) on the MultiPlus (parallel installation)
The GX sees the Pylontech batteries BMS.
The GX does not see the ESS assistant installed via VE-Configure.
I can give you remote access if you want to take a look ?
(I've someone on site if any manipulation is needed)
Thanks !
- Jean-Claude
I deleted ESS Assistant and now DDC Program error is gone, BUT .. there is 2 alarms :
Any idea why those alarms ?
Matthias Lange - DE avatar image Matthias Lange - DE ♦ jcarnouil commented ·
I just noticed that you have 2 MultiPlus (the EasySolar is basically a MultiPlus).
Do you have configured them to work together (parallel, split-phase, or whatever)?
https://www.victronenergy.com/live/ve.bus:manual_parallel_and_three_phase_systems
If not that is the problem.
jcarnouil avatar image jcarnouil Matthias Lange - DE ♦ commented ·
Both system are totally independent. (my house and a friend's one)
I finally disconnected the BMS cable from the Pylontech batteries and reconfigured the EasySolar the same way as my installation, which use a DIY LiFe4po battery pack, and it works now in ESS mode.
I'll take time later to connect it back and see if the problems are back too !
Thanks for your help
Dear all !
One month later ... and the problem is still present :(
I've used the system without connecting the Pylontech battery's BMS for some time, but it's not a solution as the ESS does not monitor the battery SOC, and the batteries goes in alarm when discharged.
I've made last week a call to my vendor (Myshop-Solaire) but they did not respond at all ! (very bad client service this company :)
Any help is welcome, and if one want to "play" with my system, I can provide him full remote access !
(and will offer a pack of beer if you find the problem ! ;)
I began to desperate .. really !
- Jean-Claude
Guest VRM access : https://vrm.victronenergy.com/installation/181865/share/b5dfc2b8
PS/ I hope my connections are correct ? (we newer knows !)
Alex Leo avatar image
Alex Leo answered ·
Hi guys,did anyone find a fix for this ? I have the same problem with Easysolar 2 GX 48/5000 and Pylontech US3000C.
