I am short charging a bank of SimpliPhi 3.8-48. I don't need to top them off and can easily stay within 54.5 to around 52.5 so I keep them in the sweet spot for life time service. But to get the SOC reset at a consistent place the charge detection time is a challenge. The manual says the range for the setting is 0 to 100 minutes. But I can't get the BMV to accept 0. In other words if current and voltage settings are met I should be able to get it to reset SOC immediately at 0 minutes. The monitor will only take 1 minute as minimum.
What am I missing?
