Will these settings work for 250/100? I want the mppt to output constant 50 volt and maximum variable current (based on solar harvest conditions), up to max current.
In theory yes. But if your battery level is low, then the Voltage will be lower than 50V until the charge level comes up.
It depends what load you have on the output. Something like a switching power supply would demand more current. A resistive load would consume less current.
Either way, the 12A maximum would remain unchanged. The Voltage would drop when the maximum current threshold is reached.
This is mostly theory though, because using the MPPT without a battery is outside of its design parameters, so a number of strange things could happen instead.
Will the charge current change if I change the fixed voltage from 50 to e.g 20v?
25 People are following this question.
