New out of box BlueSolar MPPT 75 10. V1. 16 Connected to battery with green blinking led. Use Victron Connect app but cant discover device. Have tried on win 10 also same issue. Please help
Are you trying to connect via Bluetooth? The BlueSolar doesn’t have Bluetooth I believe, only the SmartSolar range. If that’s the case then you will need either a Bluetooth dongle or the Ve.Direct to USB cable
5 People are following this question.
