zonderzorg avatar image
zonderzorg asked
MultiPlus 24/5000 not inverting from battery.
My MultiPlus 24/5000 has stopped inverting from the battery. Connected to shore power, all is fine, but unplugged, I get a low battery alarm, and the system immediately shuts down. The battery tests fully charged – actually overcharged at 28.2v, The same voltage enters the Multiplus, but nothing comes out.
Multiplus-IIinverter rs
Jason - UK avatar image
Jason - UK answered ·
@ZonderZorg What settings do you have in the config file? That would be the first place I would check. Make sure all the settings are correct for your battery type. I would also test the voltage on each of the DC connections between the batteries and the Multiplus, just to make sure you have not got a failed connection or blown fuse. A overheated joint or connection can cause a connection to create a voltage drop due to the resistance of a cooked connector. Speaking form experience on that one as I had a incorrectly fitted washer on a busbar which had a 10v drop from the battery side to the inverter. Took it apart to find a black and over cooked copper washer that had burnt to destruction under the 70mm cable connection.
zonderzorg avatar image zonderzorg commented ·
Thank you. I tested the same 28.2v entering the inverter, then I found a blown switch. Problem solved – except for the replacement.
MultiPlus-II Product page
MultiPlus-II Manual
Multiplus-II GX Online Manual
MultiPlus-II 230V Datasheet
VE.Bus Error codes
Inverter RS Product page.
Inverter RS Online Manual.
Inverter RS Datasheet.
