Hi, I have installed a Victron MultiPlus ll 12/3000. I have a flashing absorption and float LED. I have checked the software and it up to date. Im also getting a Temperature sense error but don't think its related. Any advise will be appreciated
quote from the manual for this:
"The battery temperature as measured has an extremely unlikely value. The
sensor is probably defective or has been incorrectly connected. The device
will remain in normal operation.
NOTE: If the "inverter on" LED flashes in phase opposition, this a VE.Bus
error code (see further on)."
check your wiring, particularly the Temp sense connection.
Hi The battery sense is working fine, showing the correct voltage on the app. The main problem is the flashing absorption and float error
28 People are following this question.
