I have six (6) Victron MPPT Solar Controllers. I want to connect all six to the Cerbo GX but there are a limited number of ports. Is it possible to connect all of the controllers via the VE.Can Bus or with the VE.Bus serially?
Hi @Serenity,
the easiest way is to expand the number of USB ports by using one of those USB hubs. They work just fine and are cheap to buy.
Yes, that's possible.
The more elegant solution is to use the 3 available VE.Direct and at least one of the USB ports of the Cerbo GX with the MPPTs and then connect a USB hub to the remaining USB port. Then connect the other two MPPTs via VE.Direct to USB adapter.
You didn't say which of the MPPTs you have. If they are VE.Can, forget about the above and simply connect them daisy chained to the Cerbo GX VE.Can port. VE.Bus is something different and it's not possible to connect a MPPT via VE.Bus.
We have five (5) 100/30 and one (1) 100/50 SmartSolar Controllers. I currently monitor them using the Bluetooth app. We have two battery banks that combine into a single, presently charged by another OEM inverter charger. We are upgrading to a new Victron Multi-Plus II unit. I would like to connect all devices to the Cerbo GX including our existing three (3) BVM-712 monitors.
34 People are following this question.
