Fra avatar image
Fra asked
How to connect both virtual load and mppt control to smartsolar TX port?
Good morning. Is it possible to modify the ve direct cable to connect both the mppt control monitor and a solid state relay to control the virtual load to the smartsolar?
Because in the manual it is written that the tx port continues to be able to manage the virtual load even in "normal communication" mode.
"Normal communication" mode is used for connecting mppt control. But how to connect even a virtual load together?
MPPT ControllersVE.Direct
Fra avatar image
Fra answered ·
Noone can help me? If I connect the display mppt control to tx port, lost i the ability to control a virtual load? Thank you
