duswami avatar image
duswami asked
60A 58vdc (48vdc) MEGA Fuse. Do they exist??
Need a 60a mega fuse for 48vdc system but can find them anywhere. Meant for Victron SSCC 150/45. Can't find any 70Vdc ones either. Anyone know where in the US these unicorns can be procured?
MPPT Controllersfuses
Alexandra avatar image
Alexandra answered ·
@Duswami
You can switch to a MIDI fuse holder instead of MEGA.
Amazon has 60A in those. You dont have to use the link I have attached, it is just an quick example.
9 comments
duswami avatar image duswami commented ·
So, I have the lynx distributor, really want to keep my power center for all my fusing if possible, any other ideas?
Alexandra avatar image Alexandra ♦ duswami commented ·
@Duswami
You ended up in a weird place in your system sizing between the mppt size and the lynx.
Upgrade the mppt? ;)
klim8skeptic avatar image klim8skeptic ♦ Alexandra ♦ commented ·
Given that the mppt has an internal fuse, could the OP use 35mm battery cable, and then rate the fuse to suit that?
klim8skeptic avatar image klim8skeptic ♦ klim8skeptic ♦ commented ·
Oddly enough there is a new 150-45 mppt controller ( new 150-45 ).
Perhaps the OP could clarify which mppt they have?
duswami avatar image duswami klim8skeptic ♦ commented ·
150/45 mppt
klim8skeptic avatar image klim8skeptic ♦ duswami commented ·
This150-45 takes 35mm battery cable.
This new 150-45 takes 16mm battery cable.
You could use a 125a fuse for the 35mm cable.
Maybe 60a for the 16mm cable?
duswami avatar image duswami Alexandra ♦ commented ·
Well, sorta. It's a small system. 370w panels in 2s2p, so the total Amps are low(er).
Could I use a 60a 70v fuse instead?
@Duswami
I dont see why not.
If it was undervoltage I would say no.
ahtrimble avatar image
ahtrimble answered ·
Try finding a 60 or 80 amp MEGA fuse in 70v version...no luck here. Anyone else?
hominidae avatar image hominidae commented ·
try digi-key: https://www.digikey.com/en/products/detail/littelfuse-inc/0998060-UX-2M8/15297310
Edit: oups..these 60A versions do sell in batches starting 500pcs, as it seems.....but you can find them on ebay...search for littelfuse brand, like here
mikehammer365 avatar image
mikehammer365 answered ·
Hello. Please try this amazon link. I had tried this and the 58V fuses are Ok.
https://www.amazon.de/gp/product/B0BB7G5LWX/ref=ppx_yo_dt_b_asin_title_o02_s02?ie=UTF8&th=1
ahtrimble avatar image ahtrimble commented ·
Spot on!!!! Unfortunately...they don't ship to the USA and nothing showing that would ship to the US. Bummer! But, thank you for trying :)
dchannin avatar image
dchannin answered ·
Same problem. Found them: https://www.mouser.com/c/?marcom=172767957
sean-smith avatar image
sean-smith answered ·
Have found these in Australia and they will ship internationally, have not tried them myself.
https://www.swe-check.com.au/product/pacific-70v-mega-fuse-sbfw-k
