Rene Brunier avatar image
Rene Brunier asked
Cyrix-li-Ct with MPPT75/10
Curently using a solar panel 100W associated with a MPPT75/100 to charge a 12V LiPo 55Ah pack.
This application if for an RV, so I plan to add a Cyrix-Li-Ct coupler to use the vehicule alternator when driving.I just don't know how to do it best.
1) Should the Cyrix-Li-Ct outlet (LiPo side say) be connected directly to the LiPo battery:
1653032645772.png2) Or should it go to the MPPT module (so connected to the solar panel outlet) and therefore all charging modes (bulk, float..) are still in in the play?
What is the best way to do ?
Thank's
Cyrix Battery Combiner
Rene Brunier answered ·
Reading more about this topic make me think I may need a VE.Bus BMS controller ?
Is there any risk to over load the lead battery with the voltage coming from solar panel ?
Will the Cyrix- li-Ct work on a 2018 Euro5 vehicule ?
Maybe someone with RV experience could help
Thank's
