ako avatar image
ako asked
Are the Temperature sensors interchangeable .
I just got home after collecting our Multiplus and Cerbo GX however we forgot to pick up the temperature sensor we ordered .
The Multiplus comes with a Temperature sensor and i did read that the Cerbo GX can supply the temperature for all connected equipment if it has one so im wondering if the one that came with the Multiplus is the same one that would be used or is there a dedicated one unique to the Cerbo . It would save a long journey that was possible and also be simpler than having several Temperature sensors as the MPPT also requires one .
cerbo gx
wkirby avatar image
wkirby answered ·
The sensor supplied with the MultiPlus is compatible and can be used on the Cerbo.
ako avatar image
ako answered ·
Thank you Wkirby . Now just need to work out how to set it up so the MPPT and Multiplus make the nescersary temperature compensations from the Cerbo as they wont have their own input .
have a look at the CCGX manual,
