huubc avatar image
huubc asked
MPPT tracking drops to 0 watts at full sunshine after connecting to Global Link 500
When I connect my Global link 500 to the Victron 150/35 mppt controler , tracking becomes unstable and after a minute or less the power drops to 0 Watts, even in full sunshine. A minute or so later it recovers, starts tracking again only to repeat te same pattern after a short time. The global link works perfectly and I don't see anything wrong with the smartshunt either. When I disconnect the mppt from the global link tracking returns to its normal operation. Any ideas what this may be?
MPPT Controllers
Daniël van de Giessen avatar image
Daniël van de Giessen answered ·
That is an unusual problem indeed, having a GlobalLink connected to the MPPT should not have any effect on its operation. My best guess would be some kind of electrical issue; for example a damaged VE.Direct cable or perhaps a damaged port on the GlobalLink causing a short-circuit or other interference.
Can you check swapping the VE.Direct cable and the port used on the GlobalLink to see if the cable/port in question works correctly with your SmartShunt / the MPPT works correctly on the other cable/port?
huubc avatar image
huubc answered ·
Thanks for the advice but since yesterday the Global Link device stopped functioning completely. No blinking led, no data transmitted. It's brand new and only functioned normally for a few days. .I guess I'll have to turn it in.
I am sorry to hear that the unit is not responding at all . If the LED stopped blinking completely then there is nothing left to do then return the unit for a new one assuming you checked the power supply. I hope that a new module will resolve the issue.
