lukescarr avatar image
lukescarr asked
Multiplus-II GX not displaying SOC
My Multiplus-II GX isn't displaying SOC, it never has since I installed it.
It displays "--" or says 0%
I've confirmed settings in Settings → System settings → Battery monitor
I've also tried changing it from "automatic", "MultiPlus-II 48/3000/35-32 on VE.Bus" and "No battery monitor" but it doesn't get it working.
When I select "no battery monitor" the "0W" reading disappears "(the bank currently has no load).
I've Googled around and searched the forum. Thanks for any help.
Multiplus-IISOC
JohnC avatar image
JohnC answered ·
Hi @lukescarr
If you only have the Multi available to provide SOC, you'll need to enable it in the Multi. It looks like this in VEConfigure..
1652188878279.pngBetter to grab a BMV or Smartshunt if you want a serious SOC.
lukescarr answered ·
Thanks John, that's sorted it.
I didn't see anything about having to nn specifically enable it via VEConfigure, I had assumed it was enabled by default and that by seeing battery monitor options in the remote console it was available be used.
Thanks again.
MultiPlus-II Product page
MultiPlus-II Manual
MultiPlus-II 230V Datasheet
VE.Bus Error codes
