Paul B avatar image
Paul B asked
Feeding surplus Solar power to power AC loads instead of using all the Grid when batteries are full
In the senero below how can I get the spare solar power (DC connected) that's been turned off as the batteries are full.
I do not want to export to the grid as a grid connection is not allowed, plus I have to allow for a generator to come on line and I don't want feed back to the generator.
I have tried ESS and I get return power issues to the generator plus even to get the gens to sync, I had to disable the LOM of AC in 2 (just for testing)
have tried a few other assistants as well all works well until the generator comes on line then I seem to be getting return power being feed back
Have turned off export to grid etc etc
ANY IDEAS out there or solutions would be helpfull,
we can live without it but its a shame to wast that free sun power
The available solar power is 1800 watts currently only showing 11w
System setup
2 x Quattro 24/8000 units in parallel FW 433
2 x 250/85 smartsolar regs
1 x BMV712
1 x CCGX FW 2.23
20 Kw lithium battery bank
boekel avatar image
boekel answered ·
Easiest way: program the multi to charge to a lower voltage (or SOC)
Lots of options to make different scenario's:
https://community.victronenergy.com/questions/8933/example-of-using-assistants-partial-off-grid-boat.html
