joshyjs avatar image
joshyjs asked
Wrong Batterie Temp indication
My Multiplus II 3000 has a temperature sensor with cable for the battery.
I connected the eye at the plus pole of the battery.
And made sure the connection at the Multiplus has the right direction +/-.
In the VRM it shows -9°C. The Temp in the room ist +17C.
Faulty Sensor, faulty Multiplus or wrong connected?
Or a bug?
Temperature Sensor
kevgermany avatar image
kevgermany answered ·
This one goes on the negative pole, not the positive.
joshyjs avatar image joshyjs commented ·
Thank you. I will try.
joshyjs answered ·
Tried it out. No change.
joshyjs answered ·
I finish now with that issue.
Tried diffrend poles at the battery. Changed the cables at the Victron. No help.
VRM Portal shows minimum -8° Celsius. Tempeartere is about 18 plus.
I managed now to setup a DIYBMS via CAN bus on the GX.
This works and shows reliable Battery temperatures now.
Victron temperature sensor disambiguation table - which product supports which sensor
