toddbender avatar image
toddbender asked
shunt install 4 serial/parallel batteries
My RV has four 6v AGM batteries wired in series/parallel.  Two
batteries (connected serially) are in the front engine compartment, two batteries (presumably also connected serially) are in a tray
underneath the chassis at the back of the RV (difficult to
see/access).  The batteries in the front are grounded to the
chassis and there is no wire from a negative post back to
the back of the RV.  I assume the back batteries are grounded to
the chassis in the rear.
Can I install the shunt on the negative to ground wire on just the front two batteries and get meaningful data from the monitor?  If I configure the monitor with the capacity of just two (instead of
four) batteries, will I effectively get usage data reflecting all
four, since they are all connected together anyway?  It seems to me that both the front pair and rear pair of batteries should show
equivalent draw/charge data, equivalent voltage, etc.  If the front two batteries are low, then the rear two batteries are low too.
Would there be any distortion of monitoring data in this case?
installation
kevgermany avatar image
kevgermany answered ·
If there is no common ground for the batteries, you can only get full information for the ground connection where you insert the shunt. If your shunt has a second battery function, you can also get voltage readings for the other pair.
