As i read the manual, BMV-712 SOC reading goes from 100% to 0%. When SOC shows 0%, are we actually at the discharge floor....which I understand is 50%? Or does a 50% SOC reading mean that i am at the discharge floor.
You SOC will be calculated on the battery capacity programmed in.
Your time to go will change if you change the discharge floor. For example on mine it is set to 20% discharge floor, i have 11 hours 20 minutes to go. If I change the dicharge floor, I see 13 hour and a few minutes to go. But the SOC remains the same.
26 People are following this question.
