maha avatar image
maha asked
Zero feed-in problem
We have a problem with the EM24 and the zero feed in the ESS. The screenshot shows that supposedly 0 kWh has been fed in.
In fact, however, 6 kWh were fed in.
The system has the following components:
We use the original Victron cable for data transmission. V2.85 is used on a rpi.
We have set the mains supply to 500W on a trial basis. However, this does not prevent the grid feed-in either!
Where could the error lie?
em24
marekp avatar image
marekp answered ·
@MaHa
Try changing "multiphase regulation" from "total of all phases"
to "individual phase"
maha avatar image
maha answered ·
We replaced the multi with another one and everything works fine with it. This means that the first Multi is working incorrectly. I'm curious to see how the repair will go...
