jcerioni avatar image
jcerioni asked
Is the BMV-712 Power Consumption a Problem in Cold Weather with LifePO4 batteries
My design includes 280ah lifepo4 battery monitored with a bmv-712 with temperature sensor.
The battery manufacturer states that the battery operating temperature envelope is 0 degrees C to 60 degrees C.
My question is will the power draw of the bmv-712 harm the battery when in environments beyond the battery's temperature envelope?
BMV Battery MonitorTemperature Sensor
elvis avatar image
elvis answered ·
LifePO4 can discharge to much lower temps compared to charge.
Those specs you quoted are likely charging temps.
