siebe-r avatar image
siebe-r asked
Split Phase 120° with 2 multiplus II on 3X400+N
Hi
Here in belgium we are restricted to max 10kw inverters for residential settings. On a three phase system with 3x400+N normally you would use 3 multiplus II's 3000. But in theory you can configure a split phase system with 120° phase angle. So my question is can I use 2x multiplus II 5000 in split phase mode and let the ESS compensate for the usage on phase 3?
Thanks in advance!
ESS3 phasesplit phase
