brian-new avatar image
brian-new asked
Measured amps on VRM differ from Lynx to Quattro (system, ve.bus)
My system is 2 Quattros, Split Phase Config, Lynx Shunt & Bus System, Cerbo GX & Off Brand Lithium Batteries.
I'm seeing a difference on VRM when I look at identical time windows. The Lynx portion of the system is showing ~20% lower charge amperage vs. the ve.bus system data (which I assume is coming out of the Inverters).
Is there a way to sync these or calibrate the Quattro's?
Thanks for the Help
Brian
MultiPlus Quattro Inverter Chargerlynx shunt
