50st8r avatar image
50st8r asked
Cerbo will not power up
My cerbo worked great this past year but when I went to do a system check as we were de-winterizing, I found no power and the fuse blown. I replaced the fuse but still no power. I get 13 volts off the battery at the terminal to the cerbo but it will not start.
cerbo gx
I think you have to contact the seller from whom you bought it to get a replacement.
elvis avatar image
elvis answered ·
Something caused it to draw too much power and blow the fuse.
Disconnect all unnecessary connections (HDMI, USB, Analog inputs) and try again.
50st8r avatar image 50st8r commented ·
Tried this also but Cerbo GX still will not power on with nothing attached.
