I would be grateful if you could tell me if the "Energize" terminal of the Argofet battery isolator can be permanently connected to positive.
Why's that? can you clear it up
What does the "energize" terminal have to do with the isolator function?
Am I wrong to understand that through V on the energize connection you activate the isolator, hence you connect the batts?
24 People are following this question.
