Steffen Scherf avatar image
Steffen Scherf asked
Common remote switch for multiplus II and Orion dc/dc on a 48v system
Hi there,
I got a vehicle with a 48v system and want to connect a common remote switch to turn off the multiplus II (48v) and all Orion dc/dc 48-12 with one switch.
The voltage of the remote switch on the multiplus II is 13v and on the Orion it is 48v. Could I connect them together? Are the circuit of the remote switch input on the multiplus has a tolerance for 48v?
Best regards
Steffen
Multiplus-IIOrion DC-DC Converters not smart
Paul B avatar image
Paul B answered ·
I would use one switch that turns two relays on/off one for the multiplus the other for the Orion
best to keep the two banks separte
boekel avatar image boekel ♦ commented ·
Correct, or use a switch with multiple contacts inside (dual pole, triple pole, etc), than you don't need a relay (but do need more conductors in the cable;)
I don't know if you can safely connect multiple orions to one switch, check the manual for that.
