I can easily set the shore power limit on my MultiPlus 12/1600/70. This is great and I use this at low fuse campgrounds. But I would like to leave the charging of my battery to the solar cells. However, this is only cumbersomely possible at the MultiPlus, via the MK3-USB interface. Very inconvenient.
It would be wonderful if you could enable/disable charging as easily as setting the charge current limit. Please dear developers, include this in the next update for the MultiPlus.
Thanks and greetings,
Markus.
