ilan avatar image
ilan asked
multiplus 1200 won't start after firmware update. battery show 0v
Yesterday I update my multiplus 24v 1200va frimware from v430 to v494.
All looks fine put after reboot the inverter is not turning on.
I can see it on vebus with MK3 and on the portal vrm and I get alarms that the battery voltage is 0v.
I tont have the old firmware to go back.
Please advise.
firmware update
Paul B avatar image
Paul B answered ·
try redoing the firmware update using the mk3 - this will reset the unit then to factory defaults
Paul B avatar image Paul B commented ·
also check the fuse instide the multiplus I think that version as a internal mega fuse - not 100% sure on that one.
ilan avatar image ilan Paul B commented ·
Hi Paul,
Thank you for your reply.
I solved the problem by swiching off ds1 on the dipswich.
When you upgrade the inverter using the VRM you dont get a message regarding the dipswiches (ds1 and ds2) that should be on off position.
