vomund avatar image
vomund asked
Charge Controller Load Port Reverse Flow?
I have a 17' travel trailer. We use the battery only for some basics, mostly to pump shower water in the evening, run the fridge thermostat and sometimes to run the heater fan at night. I am adding a 100W ground solar panel and a Victron SmartSolar MPPT 75/15 controller. My thinking is to take the cables that currently connect to the trailer battery and connect that to the load of the new controller. Of course, the battery and panel will then connect to the controller. However, when I plug the trailer into shore power or the trailer is being towed, current is sent to the battery to charge it. With my proposed setup, the shore or tow power would need to enter the controller's load port and make its way then to the battery. Will that work? If not, do I need to instead have the trailer's current wiring hook up directly to the battery, thus bypassing the charge controller?
MPPT Controllersbattery connection
kevgermany avatar image
kevgermany answered ·
Your proposal is the normal set up.
MPPT Product Page
MPPT Error codes
