Does anyone know how to explain the setting of current or power in programmed charging mode ? Apparently there is no current or power limit.
The charge and current limit will be whatever the battery requires or asks the system for, limited by the input current limit and battery charging profile programmed into the grid tab of the inverter.
Or in some cases altered by the DVCC settings by the user.
Also each inverter has its own max current charging ability to the battery bank.
@ Alexandra, I'll check again if limit is taken into account in sheduled programming mode.
@Alexandra . See your post on 16 April 2:45 PM, you tell that you will check if charge limit is taken into account in scheduled charge mode.
From your reply I assumed you would check and see?
24 People are following this question.
