I have a MultiPus 3000 with firmware version v430. I see that version v494 is the latest. All is working well but am I missing out on new features I might benefit from?
Hi Matthias,
do you have a link ?
I've only found:
which didn't cover v496 (newest firmware release for my MP2 according to VRM )
Thnks in advance.
Best regards
Thomas
There should also be a document "Changelog firmware.docx".
It depends on the type of system you have.
Ess or mobile?
Is there a feature you want specifcally?
I always lean into the corner of - if it aint broke dont fix it.
So if you are not trying to integrate new components (maybe a Cerbo) into the system (and it is doing everything you need to do) then there really is no need to update. Other than the one that snoobler mentioned that is the lithium charging at low temperature protection.
Most of the firmware uodates relate to ESS (so not for mobile) adding grid codes and one or two bug fixes some stuff for the newer multi2.
So not much activity for mobile application.
Maybe the on off charger switch in the GX menus?
That now is entirely up to you as you are familiar with how you use the system and what conditions it is under.
What are the battery manufacturers recommendations? Follow that.
At Victron Professional (free account needed) you can find a changelog for the VE.Bus firmware.
32 People are following this question.
