In my limited experience in communicating with the Cerbo GX via MQTT I dont need to send a keepalive but on the Raspberry Pi I have to incorporate the keepalive to maintain the messages.
This is on a local network and not using the VRM broker.
Pretty sure your Cerbo GX will require an MQTT keepalive (mine does).
Perhaps you have the Victron HTML5 app, or something else, running on the same machine that is providing the keepalive?
Do you mean the Marine HTML 5 interface?
Indeed, I do have that installed on the Cerbo. Thats interesting and insightful, If that's the case thanks for pointing that out.
Raspberry Pi running Victron’s Venus firmware - Blog Post
Venus OS Large image: Signal K and Node-RED - Install
raspberrypi install venus image
58 People are following this question.
How I can run mosquitto_sub command from python script ?
Getting Cerbo data through MQQT with a Rpi without internet connection
Lost connection to Victron Venus on raspberry pi
Cerbo GX on Raspberry pi, Physical installation of components, How to achieve it ???
Wifi Problem on Cerbo GX to RaspAP Hotspot since "Official 2.60"
