I cannot find this topic at the programming software.
Is is a solution just to disconnect the temperature sensor?
Andre
Andre
The type of battery chosen in charger tab of the config will be where the temp compensation is set up. If you choose a lithium profile and tweak the voltages, there will be no temp compensation in the charge algorithm.
The I do not need to install the sensor for LiFePo4 charging, right?
26 People are following this question.
