We run several forklifts 2,5 to 5,5 tons with 80V lead acid batteries. The capacity of each single battery is minimum 50kWh. Unfortunately we cannot use them for ESS. Why are all Multiplus limited to 48V maximum? All key components, mainly capacitors and MosFets should be easily available for higher input voltages. Also ELV insulations (Schutzkleinspannung) should be no problem up to 80VDC. As currents become lower, wiring, shunt resistors or inductors could be smaller while efficiency should improve.
