miniveda avatar image
miniveda asked
EasySolar II with BMS Configuration
I'm new to solar power and after several months of reading i kind of got several designs to deploy until recently i discovered Easysolar II and it seems it suite my needs as in my country we don't get more then 2 hours per day of electricity from the grid.
I'm planning on going DIY with the battery system (EVE 280ah 8 cells 24 Volt) so i will need the EasySolar II 3KVA. As i have read it's a simple setup to be done but what i can't find or understand is how to connect the BMS to the system (or what is the BMS that i need for such system). The reason why the easysolar got my attention is that it's budget friendly and easy install. I would appreciate if anyone can direct me what to do or at least a wiring diagram for such system and does EasySolar supports DIY battery system?
Components that i was planning to purchase
- 8 units EVE 280Ah
- Overkill BMS 8S 100Ah
- Victron EasySolar II 24/3KVA
- 4 panels 450w
- Smart shunt and bus bars
- Fuse
EasySolar All-in-One
