yobtaf avatar image
yobtaf asked
Cerbo GX as canbus to modbus tcp converter
Is it possible to extend the Cerbo GX as CanBus to ModbusTCP. I have a REC-BMS and a 3P16S system. The REC outputs the individual cell voltages via CanBus. However, on the Cerbo, only the maximum and minimum cell voltages can be queried via Modbus TCP. With a 16S system I would like to monitor the other 14 cells as well. Instead of having to install an external converter, I would like to use the Cerbo for this.
cerbo gx
