Can't connect to the device using the MK3-USB either (Computer does connect to the MK3-USB , but the MK3-USB can't find a VE.Bus device).
I was finally able to flash the firmware. Original version was 2624481, newly installed version: 2624494. System is up and running again.
Have been able to do so using VEFlash, my guess is that I did not switch the Multiplus off long enough before flashing, after having established the connection with the MK3.
What worked for me:
Connect MK3 to PC and Multiplus
Start VEFlash
Auto connect to the MK3
Load firmware file
Switch off Multiplus
Leave off for 5 seconds
Switch Multiplus on again
Upload firmware
Thanks everyone!!!!
You can usually just retry the firmware update.
If that fails do it manually with veflash and the mk3.
Make sure you disconnect the gx when connecting the mk3 to the multi.
Hi Nick, thanks for your reply. I have already tried but run into the same issue; My computer connects to the MK3 but the MK3 is not able to detect a VE.bus device.
Could I be doing something wrong?
if you haven't already, please check and try to update firmware using VEFlash. The whole procedure is documented here: https://www.victronenergy.com/live/updating_firmware:updating_ve.bus_products
Hi Stefanie, thanks for your reply. I have already tried but run into the same issue; My computer connects to the MK3 but the MK3 is not able to detect a VE.bus device.
Do you happen to remember the com port number? You should be able to set the COM port manually instead of auto detect. Maybe this helps.
If not, then I suggest you contact your dealer.
Have a great day!
Flashing led's ... Maybe a code ... Take a look at the victron toolkit ...
>> I am not able to get past a bootloader error (All LED's flashing in random order). <<
That's the code ;-)
26 People are following this question.
