joshua Richard Sabuni avatar image
joshua Richard Sabuni asked
i cant control charging current on my mppt 150|60
i have an ESS installation containing 3 quattro 8000VA connect parallel with 15KVA Fronius also i have MPPT 150|60 also connected to charge the batteries when the FRONIUS isn't working (off). cant get the mppt and Fronius to charge together under 60A(my battery bank max initial current), i can get the quattro to regulate FRONIUS charging current but its seems the charger is getting regulated
MPPT ControllersMultiPlus Quattro Inverter ChargerFronius
yes it's work when the dvvc is set to 60A
if it doesn't work , you need to check your configuration !
