Hello and hoping that someone has this figured out.
I have installed the Smartshunt in the 2/0 negative wire that goes from battery to the inverter/converter (xantrex freedom x 2000w) I attached positive power wire to the positive side of the xantrex.
I get the power reading from battery but everything else is zero until I turn on xantrex. Then I only get power draw when I use the xantrex and 120v.
I can’t get any 12v readings and this is only negative line from battery other than the one for jack and break-away.
Thanks for any suggestions.
