My chassis battery is correctly monitored from my 712 and I can see the different voltages when I connect to it via bluetooth. It is configured in the remote console to be visible, yet I can't see it in VRM. How do I fix this?
Thanks
Tom
Thanks
Tom
Primary or secondary battery in the system?
My second battery appears at the bottom of the dashboard page and in widgets but am using two monitors.
I am sure you did this already. To get that you go to system setup- battery measurements-visible.
32 People are following this question.
