roachmon avatar image
roachmon asked
Lowest temp for Smart LiFePO4 DC load operation?
Hey there,
I know the Victron Smart LiFePO4 batteries should not charge below 41*F/5*C. Is it still OK to discharge and run DC loads at 41*F/5*C or below? What would the low temp cut off be for discharging the batteries, if there is one?
Thanks for your input!
battery chargingdischarge level
wkirby avatar image
wkirby answered ·
As a rule of thumb, discharge is OK down to -20°C, although you should expect lower battery Voltage and capacity as it gets colder.
Lithium plating starts to occur when charging below 5°C which causes irreversable damage by permanently reducing the capacity of the cell. This chemical process does not occur when discharging.
https://www.victronenergy.com/upload/documents/Datasheet-12,8-&-25,6-Volt-lithium-iron-phosphate-batteries-Smart-EN.pdf
VictronConnect VE.Bus charging manual
