I'm a solar installer in the US and new to Victron Products, as well as working on the AC side of systems. I own a tiny home and decided to design a system with a Multiplus 2 x120 3kVA. The reason I chose this inverter is because I have a heat pump system that requires 240V, also I have access to reliable 50A shore connection.
Below is a picture of my panel. Note I haven't installed anything yet. This is just a straight up shore connected panel, nothing special. Here's what I do understand... Coming from my AC output one, I'll have 6 G wire feeding this panel on a 70A breaker (I'll be making room for this breaker). What I do not understand is where and how the AC output 2 will land. The top right breaker (double pole 15A) is for my heat pump. But where do the wires from the inverter actually land? I read the manual and it recommended a 35 A breaker. Is that just it? If so I'll probably need a bigger panel.
![be9ea1cf-ded9-4bee-a7ce-39a6559834d4-1-105-c.jpeg](/storage/attachments/30676-be9ea1cf-ded9-4bee-a7ce-39a6559834d4-1-105-c.jpeg)
Thanks for the help
