The light from the Color Control is always in max? And why is it always light up, no sleeping mode? I have tried to make changes in the meny but it don't change. It is upgraded the the lastest firmware.
As far as I know the CCGX don't have a ambient light sensor to adjust the screen brightness, it can only be on or off.
But in the settings -> display & language should be a setting for the delay to switch off the screen.
When I'm in the settings -> "display off time" is in 10 sek but it is alway on, it's never down.
When I try to adjust the brightness it's alway maximum brightness even if I try to decrease it.
I think the CCGX don't have the ability to reduce the display brightness.
I will test it tomorrow at our test bench.
At both I could adjust the brightness and the turn off delay.
So yous seems to be defective, you should contact the seller from whom you bought it to get a replacement.
Works on my CCGX. Tried on v2.84 and 2.73 plus it has worked on earlier versions
47 People are following this question.
