David avatar image
David asked
Two-signal BMS support
We have an old BYD site (Pierce) that was installed with the Two-signal BMS support assistant and it has been problematic with issues such as MPPT dropouts, then low batt shut down etc. The system now back up and running but the MPPT does not show up. Is it recommended to remove the Assistant, and two wires, and update all firmware etc to improve reliabiliity?
Assistants
David avatar image
David answered ·
@Daniël Boekel (Victron Energy Staff) Hi Daniel - do you have any thoughts on this question ?
