sergio-veltri avatar image
sergio-veltri asked
Multplus II: Can I set this order? 1-charge battery 2-use solar-3 use grid
I have a multiplus II 24 v 3000 w and a diy 10kwh battery pack with an electrodacus bms sbms120
it has 10 solar panels attached to the bms and victron. I want to set it up mainly as a UPS but since I have the solar panels as well I wan to use them so I can recover the investment faster. So...can I configure the inverter so that when sun comes up it charges the battery. If battery is full use energy from the solar panels and when sun goes down continue using the energy from the grid.
Thanks!
setup
