roachmon avatar image
roachmon asked
Multiplus T Sense Connection Question
I recently had an issue with a Smart LFP battery loosing bluetooth connectivity. The battery continued to hold a charge. I revived the battery by doing this microntroller power cycle procedure detailed here (https://www.victronenergy.com/media/pg/Lithium_Battery_Smart/en/appendix.html#UUID-9312e210-9b10-cb0f-31b0-dde4eb8e42f6).
The battery(200ah) was installed and connected in parallel with 2 other 200ah batteries connected to the Lynx Distributor. The battery in question had the T Sense connected on the Positive lug, as opposed to the Negative lug.
So my question is: Would connecting the T Sense from the Mulitplus to the Positive lug of the battery possibly cause the battery microcontroller to fail? Would there be any potential issues with connecting to the (+) lug other than and incorrect reading?
thanks for your help!
Lithium BatteryTemperature Sensor
Paul B avatar image
Paul B answered ·
Its not the recommended action but I do not think that it would cause the microcomputer to fail
Victron temperature sensor disambiguation table - which product supports which sensor
Battery Compatibility
