joro20092010 avatar image
joro20092010 asked
No AC out voltage passed
Product: Easy Solar 12V/1600
I Receive no AC out voltage neither in inverter modus nor ist external AC passed through.
1. Which relays is responsible for this?
2. How can I check if the relays works properly?
3. Any other idea what could be wrong?
Many thanks,
Joern
EasySolar All-in-One
Paul B avatar image
Paul B answered ·
You would need a MK2 or MK3 connected to the Multiplus and you can then see the voltage readings on the relays.
otherwise some more information would help. like what LED lights are on on the unit etc and how its connected.
are you using assistants, and what is the battery voltage at the inverter
Has it worked before and just stopped working etc etc
Also make sure its on the latest F/W (not that this will fix it just good practice when there is a issue)
